How do I configure regional date formats?
User: "Daniel Batey"
Altair Community Member
Updated by Daniel Batey
We are in the process of moving to a new server and have installed the latest 2023 version of Analytics Workbench.  We are testing some SAS scripts that worked on our old server and have encountered an issue with dates.  When I run a program that uses proc import to read in an Excel file, dates are defaulting to a string in mm/dd/yy format but when my colleague runs exactly the same program it defaults to dd/mm/yy as expected.  On our old server both of us run the same code and it correctly loads as dd/mm/yy.
We have checked our server and it is set to GB date format.  And when I check my user details on office.com it is showing as GB default date format.
Where is this setting being picked up from and how can I change it?  I don't really want this to be user specific either for obvious reasons - the same code resulting in two different results is not good at all!
Thanks
Daniel
1 - 1 of 11
    User: "Philip Holland"
    Accepted Answer
    Updated by Philip Holland
    Hi Daniel,
    The SAS language includes a number of options to control the layout of dates, but I'm not sure whether your problem relates to MS Office, Altair SLC, or the way you are importing the Excel data.
    Anyway, the SAS national options are:
    • LOCALE=en_GB (also en_US, fr_FR, fr_BE, fr_CH, de_DE, de_CH, hu_HU), which controls language, dates, currency, etc.
    • DATESTYLE=DMY (also MDY, YMD, LOCALE), which controls only reading and writing dates.
    There are also dozens of date formats, some of which are locale-specific:
    • You appear to be using a default of DDMMYY8.
    • Others include MMDDYYw. YYMMDDw., DATEw., NLDATEw., MONYYw., etc., where w=width.
    .............Phil
