I couldn't find information about which algorithm is used in HyperStudy, for multiobjective optimization method. This information is available? If not using NSGA-II, how can we embed this method into the program?
Thanks in advance
Global Response Search Method (GRSM) & Multi - Objective Genetic Algorithm (MOGA) is used for multiobjective optimization in HyperStudy.You could find more info in online help under optimization method section.
