Hello Guys,
I am trying to mesh the prototype hood of a car as per the specifications below:
| S.N | Quality Criteria | Value |
| 1 | Aspect Ratio | 5 |
| 2 | Skewness | 45 |
| 3 | Warping | 15 |
| 4 | Taper | 0.5 |
| 5 | Min. Length | 2 Units |
| 6 | Max. Length | 8 Units |
| 7 | Min angle Quad | 45 |
| 8 | Max angle Quad | 135 |
| 9 | Min angle Tria | 20 |
| 10 | Max angle Tria | 120 |
| 10 | Tria % | 10 |
When performing mesh along the fillets, I am not getting the desired warping 15.
How to construct lines in a fillet region to get a proper mesh flow?
I was able to manually edit the elements to get rid of the other issues except warpage. I tried translating the elements to get rid of the warpage problem however the elements surrounding it also started to have warpage issues if i adapted to this translation method.
Should i construct a line in the fillet region to get a proper mesh flow? what other topological modifications can i make to get a proper mesh flow there?
