- I use the tool in the link below for interface coupling,
https://community.altair.com/community/en/altair-edem-coupling-for-ansys-fluent-with-combustion?id=kb_article&sysparm_article=KB0117663
but there is an error, the three software are the default installation position, the experiment dozens of times are not good, stuck in these three days.
- I use win10 to report the following error, with a friend's win11 found that it can be used normally.
- Look at the reply in the forum, it may be the installation location is wrong, or the vs version is not supported, I changed the 2017 community edition,2019 community edition,2022 community edition and professional edition, all reported similar error C1083, as shown in the figure.
edem_version = 2022
fluent_version = 2021R2
msvs_version = 2022_C
edem_install_dir = C:\Program Files\Altair\2022\EDEM
fluent_inc = C:\Program Files\ANSYS Inc\v212\fluent
msvs_install_dir = C:\Program Files\Microsoft Visual Studio\2022\Community
adaptor_dir = C:\Users\L\Desktop\edem_coupling_build\edem_cfd_adaptor_build\
edem_adaptor_object_dir = C:\Users\L\Desktop\edem_coupling_build\edem_cfd_adaptor_build\win64
edem_library_path = C:\Program Files\Altair\2022\EDEM\lib
<_io.TextIOWrapper name='src//AdaptorInterface.cpp' mode='r' encoding='cp936'>
<_io.TextIOWrapper name='src//AdaptorInterface_temp.cpp' mode='w' encoding='cp936'>
<_io.TextIOWrapper name='src//CAdaptorQuaternion.cpp' mode='r' encoding='cp936'>
<_io.TextIOWrapper name='src//CAdaptorQuaternion_temp.cpp' mode='w' encoding='cp936'>
AdaptorInterface.cpp modified to use header IEDEMCoupling.h
AdaptorInterface.cpp closed
CAdaptorQuaternion.cpp modified to use header IEDEMCoupling.h
CAdaptorQuaternion.cpp closed
Removing temp files...
Done.
Compiling adaptor objects...
Timed out.
Not all object files found in C:\Users\L\Desktop\edem_coupling_build\edem_cfd_adaptor_build\win64.
