I'm a beginner to this solid thinking inspire and i'm not able to run one tutorial model, i'm getting the following error
Kindly help me with this error.
Chethan
Hi!
Could you kindly provide me with the model? Also please tell me the version of your software and if your'e using the student version license.
Thank you
Its a tutorial model(baseline analysis), version is 2017.3.2 and i'm not using student version.
Were you able to work with the other tutorial models?
nope
Overall how many tokens does it required to run an analysis in inspire??
Inspire draws either 15 HyperWorks Units or 15 solidThinking units.
Further when we run a simulation, it won,t consume any tokens??
No, it will not.
Hi, I'm a beginner to this solid thinking inspire and i'm not able to run one tutorial model, i'm getting the following error <?xml version="1.0" encoding="UTF-8"?> Kindly help me with this error. Regards, Chethan
Dear Chethan
Did you resolved your issue which you had raised on 6th March? I am facing the same problem, can you advice me how you had resolved your problem?
Thanks
Hi Pritish,
I couldn't figure it out, i will let you know if it gets resolved.
chethan
