convert to h3d?
ydigit
Is it possible to convert the results of c2c into H3D format (for HyperView) after the solver run? Or does it have to be done before starting the simulation ? According to the help pdf, the optio exist in Config Options. I already have the results in c2c and want to avoid rerunning the same simulation, just to get H3D format.
Hello Ydigit,
You need to run the simulation using the console to get H3D output results.
I attached a video that explains how to do it.
Jfyi, next version will allow export to H3D through the interface.
If you need help you can contact directly with me.
Regards
Pau
ptorne@altair.com
0 -
Thanks for the video /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
