Hello, I am a new user in this community
I am using hyperworks 2021.2
I have a model with multiple assemblies that i created on the Assemblies Tab to sort my model to sub assemblies
Assemblie1_old(Components)
Assemblie2_new(sub_assemblie1,sub_assemblie2,......)
when i sort components from an assemblie to a certain other assembly with the Organize tool, a duplicate is made in the destination with the original component left in the first assembly rather than Transfering the components to the new destination, and also a dependence is left between the original and the transfered component so when i try to delete one of them they are both deleted. instead i have to use remove by right mouse click on one of the components , the issue with remove is that it is not visible whene selecting more than one componenet.
is there a way to send components to a new assembly without leaving a copy in the original assembly, and is there a solution for the dependency between the components ?
I hope i well framed the issue,
thank you
