Hi, all,
When I import the LS-DYNA solver deck into hypermesh and output one component as a solver deck isolately, the other unreferenced nodes will also be output simultaneously.
As the following picture, the white nodes are unreferenced nodes showed in LS-Prepost, and I need to use ' Node edit' to cleanup every time.
So I would like to know if there any method that can help me to cleanup the nodes automatically.
https://imgur.com/a/RIdGahq
