Remote Processing Setup
User: "dlh"
Altair Community Member
Updated by dlh
Greetings,
I'm having a little trouble with simulating jobs remotely, specifically using the front-end on Windows pre-process and then remote solving on a Linux machine. I have setup ssh with passwordless login and confirmed that it works between my two machines. Next, I try launching from the gui with the appropriate Component launch options set on the FEKO Solver tab, but no joy. I then open a Feko terminal and put the particulars on the command line as follows:
 C:\Users\user1\projects\fy19\antenna_lib\ant01>runfeko ant05l_matched2 --remote-host 192.168.1.11 -np 12 --machines-file C:\Users\user1\AppData\Roaming\feko\2018.0_caf82d78\machines.feko --parallel-authenticate default
and get the following response in the terminal:
  C:\Users\user1\projects\fy19\antenna_lib\ant01>runfeko ant05l_matched2 --remot e-host 192.168.1.11 -np 12 --machines-file C:\Users\user1\AppData\Roaming\ feko\2018.0_caf82d78\machines.feko --parallel-authenticate default  Altair Feko - RUNFEKO Version 2018.2.1-12 from 2018-10-19           Copyright (c) 1999-2014 Altair Development S.A. (Pty) Ltd           Copyright (c) 2014-2018 Altair Engineering, Inc.  NOTE: Running PREFEKO locally since using remote launching  Altair Feko - PREFEKO Version 2018.2.1-63 from 2018-12-07           Copyright (c) 1999-2014 Altair Development S.A. (Pty) Ltd           Copyright (c) 2014-2018 Altair Engineering, Inc.   Creating file ant05l_matched2.fek, please be patient ... File ant05l_matched2.fek has been created:       1 metallic wire segments in free space (of which 1 are curvilinear)     388 metallic triangles in free space   Altair Feko - ADAPTFEKO Version 2018.2.1-15 from 2018-10-12           Copyright (c) 1999-2014 Altair Development S.A. (Pty) Ltd           Copyright (c) 2014-2018 Altair Engineering, Inc.   Altair Feko - PREFEKO Version 2018.2.1-63 from 2018-12-07           Copyright (c) 1999-2014 Altair Development S.A. (Pty) Ltd           Copyright (c) 2014-2018 Altair Engineering, Inc.   Creating file ant05l_matched2.fek, please be patient ... File ant05l_matched2.fek has been created:       1 metallic wire segments in free space (of which 1 are curvilinear)     388 metallic triangles in free space   --------------------------------------------------------------- ADAPTFEKO frequency analysis band no. 1 of 1 ADAPTFEKO analysis no. 1 (max. 75) at frequency  5.00000e+07 Hz           Completed subintervals:  0.0% ---------------------------------------------------------------   Altair Feko - RUNFEKO Version 2018.2.1-12 from 2018-10-19           Copyright (c) 1999-2014 Altair Development S.A. (Pty) Ltd           Copyright (c) 2014-2018 Altair Engineering, Inc.  NOTE: Running PREFEKO since file 'ant05l_matched2_fr_1_ada_1.fek' not found  Altair Feko - PREFEKO Version 2018.2.1-63 from 2018-12-07           Copyright (c) 1999-2014 Altair Development S.A. (Pty) Ltd           Copyright (c) 2014-2018 Altair Engineering, Inc.   Creating file ant05l_matched2_fr_1_ada_1.fek, please be patient ... File ant05l_matched2_fr_1_ada_1.fek has been created:       1 metallic wire segments in free space (of which 1 are curvilinear)     388 metallic triangles in free space  Launching of the job remotely on the host '192.168.1.11' Copying files to remote host ...   Altair Feko - RUNFEKO Version 2018.2.1-12 from 2018-10-19           Copyright (c) 1999-2014 Altair Development S.A. (Pty) Ltd           Copyright (c) 2014-2018 Altair Engineering, Inc.  Host key verification failed. Warning: List of hostnames not found. - Temporary directories on nodes not delet ed.  ERROR  20032:   Error opening the source file 'ant05l_matched2_fr_1_ada_1.out' for copying.   C:\Users\user1\projects\fy19\antenna_lib\ant01>
Any suggestions on how to overcome this error and get this model solved remotely?
Thanks.
v/r,
DLH
1 - 3 of 31
    User: "Mel"
    Updated by Mel
    Hi dlh
    First try remote launching without using parallel. So please remove this part from your command
    If the above works, then there is a problem with parallel on the remote machine.
    Confirm, by opening a terminal and logging in on the remote machine, that you can launch a parallel FEKO job there.
    If you still struggle, add the debug output here. You can add debug output by adding -d after runfeko, e.g.
    runfeko mymodel -d  --remote-host 192.168.1.11
    User: "dlh"
    OP
    Updated by dlh
    Hi mel,
    I did as you suggested and the simulation now runs remotely, but only on 1 core. So, now how does one take advantage of multiple cores on the remote system? If I login to the remote system, and launch runfeko from the command line there, or even the gui, I can take advantage of multiple cores with no issues so parallel processing does work on the remote system.
    Thanks!
    User: "Mel"
    Updated by Mel
    Hi dlh
    Have you tried using the same machines file for the parallel test when running while logged into a terminal directly on the remote host?
    Your previous output showed '
    This still shows something's up with the ssh setup.
    Please (1)  send the debug output, but please use an example without continuous frequency (generates too much unnecessary output) - you can use a model from ExampleGuide model A02.
    And (2) send the machines file as well.
    Thanks
