Is it possible to hide the graphic representation of the plane (big red square and X) in a clipped model?
It is currently not possible in the current version of SimSolid Standalone.
BR-
Thomas
Hi Thomas,
Not the answer I had hoped for :-) but thank you anyway.
Hi Thomas, Not the answer I had hoped for :-) but thank you anyway.
I'll ask the developper to add this feature. Meanwhile, in Inspire it is also possible to run SImSolid analysis and there you'll be able to create cut view as you want:
I'll ask the developper to add this feature. Meanwhile, in Inspire it is also possible to run SImSolid analysis and there you'll be able to create cut view as you want: BR- Thomas
Hello! This feaure (to hide a cut plane) would be very useful for reports etc. Is it expected to be implemented in new versions?
