I need to generate user defined particle size distribution (by %mass). However, this option is disabled. How do I get this right?
Thank you.
Best regards,
MQ
Hi MQ
You probably need to change the particle factory setting from "Total number" or "Unlimited" to "Total Mass"
Kind Regards
Andreas
I know that this works if you have a static factory. But honestly, i'm not sure why it is doesn't work for dynamic.
Hi Andreas & Adriano,
Thank you for your responses. The problem was resolved!
