Hello
I'm trying to transform an excel sheet using Monarch, so that I can take columns and transpose them to rows.
Essentially I'd like to take the Writer and Publisher columns below and split them out into rows. It's much easier if I showed an example to highlight what I'm looking to achieve rather than try to describe it, so here is a before and after of a small section of the data file:
BEFORE
..and what I'm looking to achieve using Monarch:
AFTER
I've also attached the excel file with both Before and After tabs so that you can see it, as I know the BEFORE screenshot above has some of the columns cut off!
I've tried using the unpivot function within Monarch, but I just can't get to the right result.
Once I can get from this BEFORE to the AFTER above, I'll then be able to use the join function within the software to join the linked publisher code to the correct publisher code to bring the publisher info up next to the respective composer rows, however I need to get through this first hurdle first!
Any help or suggestions would be much appreciated.
Thanks!
