I am not able to use short cut keys F1 TO F12,. what as to be done to make it work?
Are you sure they are configured in your computer to work as F1 to F12? In any other software, if you press F1 the help is launched?
I mean, many times, specially in laptops you have them acting as multimedia shortcuts, and you need to configure them to act as F keys.
Did you check that?
It's NOT Altair Hyperworks's issue, for sure.
Please check configuration of your PC.
On my zBook HP, I see the same and I have to disable the HP's f***** config to work.
Are you sure they are configured in your computer to work as F1 to F12? In any other software, if you press F1 the help is launched? I mean, many times, specially in laptops you have them acting as multimedia shortcuts, and you need to configure them to act as F keys. Did you check that?
i dint check i will go through it
