I am trying to place a Patch_truncated antenna from the library to a structure to simulate far-field,
When showing results on Postfeko, the antenna pattern results shown from the origin antenna placement(0,0,0) but not from the antenna position on the structure.
I figure out that I need to do the alignment twice, one for the antenna, and another for the far-filed in the configuration tab.
Is there is a solution whenever I do antenna alignment, the far-field is aligned as well?
Thanks!
A
