I want to create a joint between two rigid bodies. so I am using p45-kjoint2 for that. Lets say i have a spherical joint between two rigid cubes. But when i see the results I see different response for the different value of Kn assigned to the kjoint property. I have a 10N force on the slave node of upper cube which should come as it is on the master node of both the cubes. But it seems that the value of stiffness affects the results.
If i have lower stiffness(Kn~1e4) the upper body rotates around spherical joint without transferrring any force and if i have higher stiffness(kn~1e12) the upper body rotates very less but transfers correct force on the bottom cube.
So what stiffness do i choose to get the correct results?
