I am running OPTFEKO on the file attached. I am optimizing 4 valuables. I was only 33% on 'Total Progress' bar when there was an Error 37610. I had ran out of hard drive storage and the file had used 291 GBs. What setting do I need to change so there is less data saved on the hard drive?
Hi Wayne
Under Solver Settings, General tab, you have there the output of the matrix to file enabled. Set this to "Normal execution"
The str file will not take much space.
Hi Wayne Under Solver Settings, General tab, you have there the output of the matrix to file enabled. Set this to "Normal execution" The str file will not take much space.
Actually the str file will also grow to a large file depending on the number of optmisation steps, so you could set this to Normal execution as well.
