The file with V2 does not converge, so in the file with V3 at the end, I selected all the faces and right click properties, went to the solutions tab, and changed Integral Equation to Combined Fields. However, when I reran it, I got Error 33457. Also, I am running version v2020.1 on my laptop to make adjustments then transferring it to another computer running v2021.2. Would that cause any problems?
V2 OUT file will no upload. Below is the last part of the OUT file with the error.
SOLUTION OF THE LINEAR SET OF EQUATIONS WITH RBi-CGSTAB
Maximum number of iterations: 250
Stopping criterion (vector norm): 3.00000E-03
Per process, 210.533 MByte of memory has been allocated dynamically,
which corresponds to 5.006 GByte in total for all processes together
(peak memory usage of 211.215 MByte per process so far)
Stopping after 250 iterations with a minimum residuum of 5.04915E-01
ERROR 33498: Maximum number of iterations reached without convergence
Aborted: 2021-10-14 20:42:14
Received message from server process 1:
Received message from server process 2:
Received message from server process 3:
Received message from server process 4:
Received message from server process 5:
Received message from server process 6:
Received message from server process 7:
Received message from server process 8:
Received message from server process 9:
Received message from server process 10:
Received message from server process 11:
Received message from server process 12:
Received message from server process 13:
Received message from server process 14:
Received message from server process 15:
Received message from server process 16:
Received message from server process 17:
Received message from server process 18:
Received message from server process 19:
Received message from server process 20:
Received message from server process 21:
Received message from server process 22:
Received message from server process 23:
