Can Flux take complex permeability with frozen technique? which means the spatial quantity of complex permeability on nodes?
Hi Wenjun Zhu ,
I have done test in Flux and we can not store a complex value with the Frozen permeability technique.
What is the application in this case?
Best regards.
Cyril Favre
Hi Wenjun Zhu , I have done test in Flux and we can not store a complex value with the Frozen permeability technique. What is the application in this case? Best regards. Cyril Favre
Thank you Favre. I am trying to analysis the eddy current harmonics in the iron core of a motor which is biased by the fundamental excitation.
