I got a 4-terminals solid conductor in my circuit. but cannot find the way to compute the voltage across A and B.
Hello Wenjun,
To compute voltage across two terminals in N terminal solid conductor, include a resistor parallel to terminals across which voltage should be computed. Then, resistor voltage is voltage across the terminals.
Thank you,
Lavanya
