How do we setup a heat generation rate for a model in hyperworks cfd. Also if there are any shortcuts too used in hyperworks cfd let me know.
Hoping for a quick answer
Thanks in advance for the answers
From the Flow ribbon, click on 'Sources' from which you can define a Heat Source Watts per unit volume or Watts per unit mass.
The 'Help' tutorial ACU-T: 3200 under the Heat Transfer heading covers defining a Heat Source in terms of W/m^3.
