Can we directly import FE model to new Hyperworks CFD interface? if yes, then why i am facing problem in setting up the deck for my problem, it is only showing solution for Solids and surfaces.
When you mention 'new HyperWorks CFD' - do you mean HyperMesh CFD 2023? Or what is now the 'old' HyperWorks CFD?
What mesh format are you trying to import - and where was the mesh created?
The mesh would be represented by solid bodies and/or surface bodies. The material selected to apply to the solid body then determines the behavior of those solid bodies by the solver (fluid or solid).
Can you elaborate on the problem(s) you are having with the setup? Maybe attach some images if they help to describe what you see?
