I want to replace nodes of all the elements in my model with minimum height less than 10mm in hypermesh is there any shortcut for this?
i have an idea, not sure if it will work in this case.
you can check your elements for minimum length, click in 'save failed'.
Then you could isolate these failed elements (use 'retrieve' selection), and go to the 'edges' panel, and try the equivalence them with a small tolerance. Nodes within this tolerance should be merged, i believe.
You might also need to show/unmask adjacent elements to make it easier to work.
