How to run model checker in scripts to find untied nodes in a tied contact? <?xml version="1.0" encoding="UTF-8"?>
Can this model checker do that?
I think we need lsdyna solver to check unconstrained nodes in tied contact (like spotweld)
In Lsdyna profile, we can run 'Untied node check' available under warning section in Model checker. I need to run this particular check in Script itself.
Did you explore the configuration file?
Is there some relevant codes inside?
I found the solution. Script is already available in HM itself to open the model checker and run the 'Un-Tied nodes in Contact Tied' check.
does it work for contact spotweld in dyna properly ?
