I have a mesh of an airplane on witch I have construct a monopole lambda/4, wire radius lambda/20 at 1.5GHz. My request is refering to far field. I want to solve it with RL-GO but it returns the following error:
"ERROR 47180: MoM segments cannot be in contact with RL-GO triangles"
First question: when I construct the line, I can not choose the kind of solution that I want. Is it because Feko implement only MoM in this case?
Second question: I read the documentation about how Feko implements the RL-GO solution and it says that "Feko integrates the RL-GO method with the current-based MoM, by launching rays from each radiating MoM element". So it seems to me that RL-GO method in Feko does not create triangles. Why then does the description of the error speak of triangles?
Third question: I tried to use as a solution the PO - full ray - tracing for large elements and in this case it works. Why solving with PO it works while with RL-GO doesn't?
If someone can tell me how to solve this problem, it would be great.
Thank you.
