Hi. I have to simulate a connection between a bolted plate and a sandwich panel. I know the reactions on the bolt and i would to transfer these to the panel in order to consider also the contribution of the plate. Is there any tools for this ?
can you share some pictures of what you need?
If you have the reaction forces, you could map them as forces?
But probably you need to do it manually.
By the way, what software are you talking about?
