I have designed the loop and monopole antenna. I am facing difficulties to get total gain in a vertical cut and near fields in 3D view in postfeko Could you please direct me how to view the total gain (in dB) in a vertical cut of the requested far field pattern using a polar plot? In addtiion,please give me the direction how to view near fields in 3D view in POSTFEKO.
Thanking You,
Golap
Hi Golap,
please check the the "Feko Getting Started Guide". For the horn antenna of example 1 these postprocessing workflows in POSTFEKO are explained step by step.
Best Regards
Christoph
Dear Christoph,
Thank you for your reply.
I checked but still facing issues to get the desired result.
Please guide me ( if possible with step by step screen shot) to get the attached desired result for the loop antenna..
