hello everyone
I have N .unv create by ncode and i want to fuse then only 1 file so that i can work with then with script later on.
The .unv start with :
" -1
2414
1
Safety factor
1
vertical
3130440
Results Set 1
WORST
1 1 1 94 2 1
1 1 1 1 1 1 1 1
1 1 1 1 1 1 1 1
And end with a :
"-1"
I know that 2414 is the block info ( as found here HyperView Interfacing – UNV Files (altair.com)). but i didn't manage to concatenate 2 .unv so far.
i tried to juste pus then one after the other -> only the first was read.
to remove one of the "-1" to see it solve it -> the file isn't readable by HW anymore.
to remove both "-1" and let the next 2141 open the block but only the first was read .
Best regards
