I am using HyperMesh and OptiStruct as Solver.
I want to connect two 3D meshed blocks with a 2D meshed 2mm thin Surface. The Connection is stiff like it is one part or a Welding Connection. So no DOF is allowed at the border of the 2D and 3D elements.
But my test model behaves like a hinge Connection and rotates freely without any deformation.
I already tried to model the Connection with and without an attached Surface. In the end I Always checked the Connection area via Tools - Edges - Preview Equiv - Equivalence and made sure the nodes of the Elements are on Point.
How do i model those geometrical 2D/3D Mesh Transition Areas to get Deformation results?
Model File and Picture is attached.
Thanks in Advance.
