Request to make connectors and joints loadcase specific. That way you could turn on or off connectors and joints for specific loadcases. This is important for running an optimization as all loadcases need to be considered at the same time but connectors and joints are either on or off for all loadcases. Maybe this could be expanded for other connections/features like contacts, masses, bodies etc.
I understand that defining the model in Inspire motion you can export all the loadcases as forces and supports for various model setups but enabling the above would give greater freedom to setup loadcases.
