Internal error in boolean (A-B,B)
User: "AADARSH CHANDRAN"
New Altair Community Member
Updated by AADARSH CHANDRAN
I am doing my major project where I have to do static analysis on the knee joint. I imported the stl files and made them into solids then deleted the mesh. I have made the model such that the parts superimpose each other.  I am trying to do the boolean operation (A-B,B) to make shared surfaces between them so that I can get a node-to-node connection for final meshing. But at some places, it starts processing then it gives the message- internal error. I read somewhere that using all internal faces options might solve this problem. But it is not available in (A-B, B) Can anyone please help me in the same.
Also if there is another way to make a node-to-node connection then I can apply the boolean in the modeling software blender, from where I have exported the stl file.
Aadarsh
1 - 1 of 11
    User: "Chayan"
    Updated by Chayan
    Hey Aadarsh,
    Sounds like there are some geometry artifacts you are encountering.
    Another approach you might want to try (since your eventual goal is to have a solid mesh) is to continue working with the mesh (and not go the geometry route). In other words,
    1: Clean up the stl mesh using tools like remesh, mesh coarsening, rebuild etc. This should enable you to have a uniform mesh, from your stl. Coarsen mesh has helped me quite a bit in the past on messy stl geometries.
    2: Once you have a clean mesh you can use tools like imprint, or manual approaches to define your shared surfaces
    3: Define your node to node connections and then
    4: check to make sure you have good element quality and the meshes enclose the volume
    5: tetmesh the individual volumes
