Hi all experts,
Can you explain for me the Microporosity format result in Inspire Cast? It is % and I'm not clear about that.
Microporosity = 4.3% so what does it mean?
Thanks all.
Hi Nancy,It means that the part will be having 0.43 % microporosity for the localized volume of the part. (as selected by the slider). The % from the slider shows the microporosity in the localized volume, and it the same for porosity results as well.I hope this helps.Thanks.
Hi Saurabh, can you clarify if you mean 4.3% or 0.43%? If the latter, why?EDIT - Nevermind, I see the original image was 0.43%!
