Hi all,
Can I create connectors (Point) with type = spring and element type = SPRING3N?
Hello @Lương Ngọc Lâm ,
the Connector control spring currently allows SPRING 2 nodes only. May I ask you about the reason why you would like to define a 3node spring? That couldhelp me to propose you a work-around?
Best Regards,
Michael
