Hello
I used a mini usb cable to connect the dsp board to the computer, to use the software oscilloscope.
But the following error is displayed, what could be the reason?
Thanks
I fixed the above error
Now the following error is displayed
Where is the problem?
Hello againI fixed the above errorNow the following error is displayedWhere is the problem?
Hello again
I also solved the previous error
But now the output variables are not displayed, what is the reason?
