FEA error output
User: "allen_21155"
Altair Community Member
Updated by allen_21155
Here are some details for the linear static analysis error output file. Can anyone have some ideas to solve it?
 *** See next message about line 451274 from file:
C:/Users/yu3/Desktop/global/global 1.1 spot.fem
"RBE2 160 44075 123456 44075"
*** ERROR # 2319 *** in the input data:
GMi # 44075 references itself recursively.
*** More of ERROR messages # 2319 were suppressed...
*** See next message about line 1006159 from file:
"MAT1 2507632.0348091.00.35 1.05-9"
*** WARNING # 1030
Consistency requirement E=2G(1+NU) violated (by 85%).
Different values of G (either provided or inferred depending on element type)
will be used. See the Material Property Checks section of the documentation.
MAXIMUM DISK SPACE USED 1 MB"
1 - 1 of 11
    User: "PaulAltair"
    Accepted Answer
    Updated by PaulAltair
    Yea, I get what you mean, but that existing mesh is combined mesh (both 2d and 3d are bounded together, and I don't know how to separate) and included in that 3d model component. And their geometries are now separated, so I'm thinking to remesh them individually. And I wasn't meshing that model (receiving it from others), I'm just combining several components and running the FEA on a global assembly. That attachemnt is that 3d model. If you can separate their mesh, that will help me a lot!
    Ok, if you are redoing then that is fine, but you can organise elements 'by config' and select the shells only to move, they can remain 'joined' together at nodes (or even shells that are on the faces of the solids, that is ok), there is no need to 'separate' them physically
