Linear static analysis error output
User: "allen_21155"
Altair Community Member
Updated by allen_21155
Here is an error message when I run the linear static analysis, Does anyone have an idea how to solve the issue? Thanks! By the way, I use rigid spot connectors to bound different components in order to load transfer.
"There were 56 error messages during input processing.
The first message is repeated below:
*** See next message about line 451264 from file:
C:/Users/yutongchen3/Desktop/global/global 1.1 spot.fem
"RBE2 150 46467 123456 46467"
*** ERROR # 2319 *** in the input data:
GMi # 46467 references itself recursively."
1 - 1 of 11
    User: "PaulAltair"
    Updated by PaulAltair
    This RBE2 has the same node defined as both a dependent and independent node (not legal)
    You can check in HM validate panel 1d, dependency (include dependent nodes)
    image image
