I have a problem with tetramesh. I received the follow error:
Vol0:shell element region incomplete.
1 Surface failed and saived .
Someone can help me ?
You can retrieve the failed surface/element using the following option in the panel:
Tool > find > surfs/elems > retrieve
After you retrieve the surfs/elems, you can click on F11 (quick edit panel) to repair it.
Koushik Chandrashekhar
Associate Engineer - CAE
