hi I have a problem with my model. I am applying forces to a helicopter blade but I get a displacement of about 8 meters when I should have values below one meter. The forces that I enter are the gravity (grav card), the centrifugal force (rforce card) and the thrust along z equal to 7786N. If I run the analysis without the thrust I have displacements of the order of millimeters while when I put the thrust I have absurd displacements. I tried to insert it in different ways both in point and distributed load. Someone can help me?
