I am trying to simulate this hopper spreading mechanism by making it move across the platform. I will dispense particles as it moves. As you can see, the hopper is equipped with an auger, which will continuously rotate to allow the particles on top to pass through. I had no issues with making the hopper mover across the platform at a certain speed. However, I am facing issues with making the auger continuously rotate while moving across with the hopper. The auger tends to not move with the hopper and it also travels upwards while rotating for some reason. I have attached pictures of the motions I have applied.
Thank you for your time and consideration!!!
