Dear,
I am trying to trim a solid with a surface (plane), but weird thing is happening as you can see it on the attached image. You will find also the hm file.
How can I solve this as it is a part of a big model.
Best regards
Nestor
Dear,
I have a model with different solids for meshing purpose. But the problem is that I can't do any boolean operation between two solids. I got an internal error. What could be the problem?
Best regards
Nestor
