How to find nodes in 2D mesh like "by adjacent"?
User: "liangycc"
Altair Community Member
Updated by liangycc
Thanks to all of you for your valuable time and efforts putting in helping others.
I want to redefine smooth for 2D mesh.So i need to get adjacent points of a point(It seems to be connected by a line),like:
*createmark nodes 1 nodeid
*appendmark nodes 1 'by adjacent'
set nodelist  [hm_getmark nodes 1]
Unfortunately,it is not acceptable for node.I spent a lot of time looking for this function but couldn't find it.
If you know how to do this, it will save me a lot of time.I am very grateful for your help!
Thank you very much!!!
1 - 5 of 51
    User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    Have you tried *findmark command?
    User: "liangycc"
    OP
    Updated by liangycc
    yes,i tried this.i used it like:
    *findmark nodes 1 1 1 nodes 0 2
    But it said that nodes are not attached to node.I think the reason for the error is that 'by attached' is not acceptable for nodes.
    User: "liangycc"
    OP
    Updated by liangycc
    Hi,<?xml version="1.0" encoding="UTF-8"?>image.png.fd89567a324dd76b1cd335e595590d67.png
    User: "tinh"
    Updated by tinh
    Hi
    *createmark elems 1 'by node' $nodeid
    set nodelist [lsort -unique [join [hm_getvalue elems mark=1 dataname=nodes]]]
    User: "liangycc"
    OP
    Updated by liangycc
    Hi
    Although the final  result is not the same as I originally thought, this is enough. Thank you!
