Thanks to all of you for your valuable time and efforts putting in helping others.
I want to spit the quad element by control,for example,the spit line is created by two points i choose.
The command i find in api are:
*elementqualitysplitelem elem_id
*elementmarksplit mark_id crosscode crosscode_size
However,this two commands spit element automatically,not under control.
Does it have other commands i do not find?
Thank you very much!!!
There are limited ways to split quad which are specified by crosscode crosscode_size
Try several ways and looking how these args work
Thank you,i find the way finally!
