Hi! I am trying to simulate a multilayered antenna, top layer is patch 2nd layer is substrate and then air gap layer between the ground plane and substrate. By using infinite ground plane I am getting results near to HFSS simulations of my structure, but when I try to simulate actual structure with 120mmx120mm ground plane characteristic modes plots are weird as it has sudden jumps at every frequency
