Hi! I am trying to simulate a structure which has an annular ring on the patch surface around the probe feed. This gap around the probe is introduced for matching purpose, I want to see the modal weighting coefficient for the design but issue is that inner probe with this capacitive gap is not coupling to the structure. I have simulated same structure in HFSS and it is giving me proper matching around the required frequency but FEKO can not utilize this gap and zero power from the source is coupled to the structure. I need suggestions
