Can anyone please explain why am I getting this error
Hi RF Engineer
This ERROR 40161 is a general error and usually indicates that the model includes some setup item or setting that is not supported along with Characteristic Mode Analysis.
Are you able to share this model?
Kind regards,
Johan H
Hi RF Engineer This ERROR 40161 is a general error and usually indicates that the model includes some setup item or setting that is not supported along with Characteristic Mode Analysis. Are you able to share this model? Kind regards, Johan H
I am trying to replace upper structure with some similar shape, so that I can post design file here. Its related to my thesis so I can not post structure
Hi! I have replaced my irregular top layer with a simple layer, it is not giving me error in case of simple shape but when I again place irregular shaped structure over substrate I get this error. Can you please explain why am I getting this error
Hi! I am using exact structure but upper layer of Perfect Electric Conductor is an irregular shape instead of triangle, when I simulate triangular structure simulations dont stop but when I replace it with actual structure it FEKO stops simulations
@RF Engineer
Hi ,
Could you please share some pictures of your irregular shaped geometry, something similar? I have tried some irregular structures and it didn't stop.
Thank you
Sumith
