Hi! I need some information regarding the sources which can be used for characteristic mode analysis of antenna, which sources can be used? as for modal excitation coefficients, source is required in the design.
All the sources that are supported for MoM should be supported for CMA.
I am at beginner level user, can you please mention topics of the help documents where I can look at the sources supported by MOM.
Hi @dilaawaiz,
I think UserManual.pdf chapter 2.22 Sources would be a good starting point.
Hi @dilaawaiz, I think UserManual.pdf chapter 2.22 Sources would be a good starting point.
Thanks for the response.
