Issue in the Graphics Window of HyperView. The Legends bar does not display after contour plots are requested ?
Any settings can be done under Edit Legends tab ?
Hello Rajesh,
This issue is usually due to an outdated graphics driver.
Kindly check all the points listed in the document below:
Windows local : https://community.altair.com/community?id=community_blog&sys_id=85f88aea1b9fb410507ca6442a4bcb88 Windows remote : https://community.altair.com/community?id=community_blog&sys_id=8085bdea1b1fb410507ca6442a4bcb73 Linux Local : https://community.altair.com/community?id=community_blog&sys_id=de2d0ae21bdfb410507ca6442a4bcb78 Linux Remote : https://community.altair.com/community?id=community_blog&sys_id=8929bd621b5fb410507ca6442a4bcb20
Also, please go through the attached "Altair Hardware recommendation" document & make sure the GPU's are matching the requirements.
Kindly update the GPU drivers as recommended in the document.
Kind Regards,
Paola Alvarez.
Hi,Laptop with the following Graphic Card - AMD Radeon Vega 8 Mobile Graphics – won’t support the HyperView 2022.3 ?
Laptop Hardware Configuration:
HP 245 G8 Laptop with AMD Athlon Silver 3050U APU / 8GB RAM / 1TB HDD / Windows 11 / AMD Radeon Vega 8 Mobile Graphics
However, the Altair HyperWorks Package is installed on cloud machine -> Windows 365 Cloud PC
– the cloud machine configuration is -> Cloud PC Business 8vCPU/32GB/128GB
Thanks!
RAJESH
Good morning!For Cloud PC, the GPU details are as follows:
