HelloI wrote the program in simulink and used the make decision block in it, now how can I rewrite that block in psim to be able to generate code?
Hi Reza,
i would recommend using the c block in psim and doing writing your logic in C. I have highlighted the main parts. When you define the number of inputs and outputs at the top you automatically get input and output variables created (xn,yn) respectively. You can rebuild the logic with "mux" elements if you are keen but it would be messy.
