Hello everyone,
I'm using Optistruct solver and I'd like to add 3 kg on the white surface for a static analysis and a normal modes one.
Does someone know how?Thank you
you can use the 'Masses' command to add a concentrated mass and apply it to a RBE3 element connected to all nodes of this face.
Or you could use NonStructuralMass (NSM) and add a mass/area to your shells.
you can use the 'Masses' command to add a concentrated mass and apply it to a RBE3 element connected to all nodes of this face. Or you could use NonStructuralMass (NSM) and add a mass/area to your shells.
Thank you!
