Activate and Flux Coupling
Sangeet Yadav
Altair Community Member
Hi!
I am working on a motor project, and I want to simulate the motor behavior with PWM signals.
The motor block generated has voltage sources as inputs, as as you can see I am providing the voltages as inputs. Here, I am getting the error:
Is there any initial condition that I have to set? Please provide your suggestions if anyone is working with co-simulation blocks.
Also, if I want to provide current as the inputs to the flux block, it works:
But if I want to give current inputs from the inverter block (see image in upper question), how ca I connect this flux co-simulation block to the Inverter output?
Thanks,
Sangeet
