Hi All!
I am using the Power Converter block DCAC (Multiphase Inverter).
I am getting the below error while running the simulation:
[ThreePhaseInvertre]: Error: Error, (in MapleSim:-Modelica:-Flatten) in `vss_ThreePhaseInvertre_im.container.subcontainer` connecting scalar to array in connect(BooleanPulse.y,inverter.fire_p)
( 99 )
Block(s): connecting scalar to array in connect(BooleanPulse
Model: ThreePhaseInvertre
As far as I understand, I am not able to connect the Gating signals at inverter, neither using the singal boolean signal or using MUX to give pulses.
Can anyone guide me how to give pulses to this inverter block.
Thanks,
Sangeet
